sub in corner well
Old 06-27-2007, 09:35 PM
Kings Z28's Avatar
Default sub in corner well
Is there a box that will fit a 12" sub in it and then fit in the corner well? I know there is boxes made to fit in the corner well, but is there any that will hold a 12" sub and fit?
Thanks
Old 06-27-2007, 10:00 PM
Kings Z28's Avatar
Does anyone know?
Old 06-27-2007, 10:02 PM
MikeD101898's Avatar
Just go with a quality 10 that fits perfectly in there.
Old 06-27-2007, 11:35 PM
SchultzLT1's Avatar
i saw a 12 in there once but it was a custom box that took quite a bit of work to get to fit with the right amount of cubes inside, i would just buy a regular one and go with a nice 10
Old 06-28-2007, 12:36 PM
KEE AUDIO's Avatar
You can, but most 12" subs require about 1.0cu.ft. of airspace volume to operate properly or more. A stealth enclosure is only .6-.7cu.ft. so your gonna have to find a 12" sub that operates in that amount of airspace...most do not. You can always fab one up from glass but it would have to extend up into the area where the wheel hump is. This would be the only way to get the airspace volume you need. There is actually more room for that on the passenger side if you remove the spare. Here's a tutorial on how to make one: http://www.fbodyaudio.com/articlevie...tealthbox.tech
There is all kinds of good there as well!!
