Professional Products Intake Arrived..
Old 06-28-2007, 10:30 AM
TARZAN's Avatar
Default Professional Products Intake Arrived..
Well, I know things have been iffy, but I don't think I've got anything to lose....So, I'm gonna try it out and see what happens.
Intake got here last night, all the pieces look nice enough, only thing wrong was that mine came with the paper style gaskets. I called up Prof. Prod. and they were extremely nice to deal with. My new O-Ring style gaskets are on the way. Mine is part # 52061 for anyone interested in how it does....
I'm dropping it off this afternoon to get ported and cleaned up. A good friend of mine is a machinist and he's excited about the project to .
As soon as the porting is done, we'll be putting the car together to see how she does...
-Will
Old 06-28-2007, 11:07 AM
AINT SKEERED's Avatar
what size throttle body WIll? they seem like a nice peice if you are spraying alot.
Old 06-28-2007, 11:34 AM
shudog's Avatar
Definitely keep us posted on the install and results. I've been following these intakes for awhile now and I'm really on the fence about getting one due to rumors of questionable fitment and results. I have read about good service though so hopefully all the bugs are being worked out. I have an LS1 manifold but would upgrade to the Professional Products for the appearance if the performance is equal or better to an LS6 intake. Consensus sounds like it is, but not as good as the FAST intake??? Anyone with input on this, post up!!!
Old 06-28-2007, 02:31 PM
TARZAN's Avatar
85mm TB, I've got a ported stock one. I hope it works well for a nitrous car, because I'll be plumbing it for my direct port before it ever goes on the car.
I'll definitely keep you updated on everything, hoping the port job helps open it up a bit. Also hoping it seals up nicely and whatnot...
-Will
Old 07-03-2007, 07:42 AM
udlose99ta's Avatar
so you ordered the o ring gaskets from professional products? how much were they?
Old 07-03-2007, 10:25 AM
TARZAN's Avatar
If you have an intake, the o-ring gaskets should have come with it, if not, they will most likely supply them at no cost.
-Will
Old 07-03-2007, 11:33 AM
udlose99ta's Avatar
yea i just got mine friday and it came with the paper style gasket. I guess i will give them a call. thanks.
just gave them a call and they are being shipped out today. thanks.
Old 07-03-2007, 12:52 PM
TARZAN's Avatar
No problem man, make sure and keep us up to date on your progress as well...
-Will
Old 07-03-2007, 03:11 PM
udlose99ta's Avatar
i actually have have ran my intake at the track already vs. my ls6 intake. i actually lost 1 tenth and 1mph. I could say the 1 mph was because of going from drag radials to slicks but i dont know about the e.t. I WAS at a diff track than usual so i hope thats the reason for the change. i have the intake off right now to put the new gaskets on and ill keep you posted. I also do not have the 85mm tb i have a stock ported one.
Old 07-03-2007, 03:46 PM
TARZAN's Avatar
Same here on the TB man, hope the gaskets or something were the problem and you pick up a lil time...
-Will
Old 07-03-2007, 03:50 PM
Eurospec2's Avatar
i have used some of the parts in the past on different motors (not GM's), id seriously doubt that manifold makes 1 HP more then an LS6, and its gonna heat soak, but please keep us informed of your results!
Old 07-03-2007, 06:16 PM
chae's Avatar
Heat soak isn't an issue unless you are sitting at a stoplight. It is common misconception. It has been beaten to death in other threads so I won't argue, but once you start moving the air moves so fast through the manifold that it doesn't make a difference. How come hardcore drag racers pay $3000+ on a sheet metal intake.
I have heard major problems with the Typhoon as far as fuel leaks and the manifold not sealing correctly to the cylinder heads. I went with an LS6. Same gains and it's cheaper and still looks stock. If you must have something that doesn't look stock get the BBK SSI from New Era Performance for $399.99. Or you could just wait it out and save up for a FAST 90/90. Even though a lot of guys run that set-up, I can't justify spending $1000 on 15-20 extra horses. I'd rather put the $1000 toward a 9-inch rearend.
Old 07-03-2007, 08:13 PM
TARZAN's Avatar
Well, I'm hoping some port work will help out a lil bit, and I'm not worried about heat soak, I have a bottle with about 950 psi of "cool" in it
-Will
Old 07-03-2007, 08:15 PM
chriswtx's Avatar
pics...pics...
Old 07-04-2007, 11:13 AM
dan_e's Avatar
*subscribing*
If you need some help with the install, let me know. Expect it to idle bad first couple of times. It really needed a tune to get it right. Watch for leaks at the fuel rails and dont over tighten anything. I pinched an injector oring, so I would suggest you get a top and a bottom or two as spares before you start wrenching.
My results are here, in case you are curious: https://ls1tech.com/forums/showthrea...hlight=typhoon
