new adjustable clutch?
i have a 99 z28 m6 w/109k on it. i put a centerforce dual friction clutch on it and since i cannot shift 1-2 2-3 under load. just puttin around is no problem. but in the upper rpms i can get it out of 1st but have to wait to go into 2nd. now any time i bleed the system i can shift hard for a little time but goes away. 2 nights ago i did the drill mod. shifted that night. but last night i could not beat on it. do i need an adjustable slave or master cylinder?
That Is Attached To The Clutch Pedal Right. Not A Mechanic. But When I Put The Clutch In I Bought The Upgraded Part That Has The Throwout Bearing In It In The Tranny. Is That The Master Cylinder?
