New LS1 Owners - Newbie Tech - TA LS6 intake on '00 Vette?
Will the LS6 intake off a 01 TA swap right over to a '00 Vette LS1?
Im looking to get one ASAP, and I just need to make sure that the swap is straight forward as it would be with a LS6 intake from a Vette.
Thanks guys
six_string_wiz
06-29-2007, 06:31 AM
Im pretty sure the intake manifold is bolton to all 98-02 applications.Its a good cheap mod as far as what others say around here.
SSW, that's what I was thinking, but I remember reading something about a different way the TB mounts to one of them...might have been on a Camaro though.
Switchblade
06-29-2007, 11:21 AM
The throttle body on both the Camaro and the T/A are identical and both are cable-driven (throttle body & gas pedal are connected). The throttle body on the LS1/LS6 corvettes are drive by wire - meaning no physical connection between throttle body and gas pedal - thus the computer interprets the signal from the gas pedal and adjusts the throttle body accordingly.
The LS6 intake should fit onto an older LS1 vettle - just make sure that the intake has all the provisions (holes, etc) to accept a LS1 vette throttle body.
NC98Z
06-29-2007, 11:53 AM
The only thing different is the steam tubes that are located under the intake. You'll have to get the LS6 ones.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
