Sponsored by: DashLynx
Center Console removal
Old 06-30-2007, 10:24 AM
ssokolich's Avatar
Default Center Console removal
Hi! I'm trying to remove the carpet from my 99 LS1 camaro for cleaning and am having difficulty removing the center console. Specifically removal of the shift ****. I have an automatic. Anyone know how to do this?
Old 06-30-2007, 12:32 PM
Copy & Paste Moderator
VIP1's Avatar
There is a staple in the front of the auto shift **** (facing the radio). Pull out that staple and pull the **** up.
Old 06-30-2007, 12:33 PM
TheLS1Kid's Avatar
There is a pin you have to tap out.
Its right on the ****. You cant miss it.
Old 06-30-2007, 12:52 PM
ssokolich's Avatar
Default Thanks Guy! Worked like a charm
I'd have been looking forever before I'd have found that staple.
Old 06-30-2007, 05:56 PM
sneaky7980's Avatar
its on the fwd side, you'll feel a slit/groove. A scribe or small flathead will pull it out. to put it back in needle nose pliers work good sine you have to compress it a little. good luck getting the console out over the shifter and e brake! You'll have to recline your seats and alternate between sliding them forward or backwards. Camaro's are a little easier than birds
JG
8675309
Old 07-26-2007, 01:22 PM
Ryan33187's Avatar
how the hell do u get it over the e-brake im having so much trouble with that right now :/
Old 07-28-2007, 08:17 PM
motownZ's Avatar
the bolts for the console are where you open the center glove compartment
Old 07-28-2007, 08:41 PM
presto_z's Avatar
pull the ebrake up as high as you can.. with some slight wiggling and jiggling it will slide over it.. or you can take the handle off but you need those starbits with the hole in um..
Quick Reply: Center Console removal
