SLP Subframe Connectors/Original Exhaust
Old 06-30-2007, 01:56 PM
97V8Bird's Avatar
Default SLP Subframe Connectors/Original Exhaust
I was wondering if anyone else has installed SLP's bolt-in set, on a mostly stock 93-97. I just installed some on my 97 Formula, and there's interference with the exhaust. It rattles against the the subframe just behind the cat on the right side. I've still got the stock pipe from the cat to the muffler. I asked a local shop, and they said that SLP designed them to work with an after market cat-back system. Is that likely true? Thanks!
