A/C block off plates?
so im deleting my A/C and was wondering if there were any block off plates where the two hoses connect in case i decide to put it back on. so are there any plates or do they just get left open? thanks
track only car? if not why bother, it does not weigh much and the compressor cuts out at WOT.
if you are hell bent on deleting it cut a couple peices of metal with a hole drilled for the bolt and make a rubber gasket to go in between. leaving them open is not a good idea it you ever plan to use it again.
