Trans is coming out again. #*^$!
1. Put in Tex clutch last summer
2. Pulled it again to replace the 2-3 slider.
3. Broke 2nd gear about a month ago, pulled it again.
Went to the track Friday to see what it might do. Short version - Hydraulic fluid coming out of the slot in the bellhousing and no pedal.
Less than a hundred miles on '02 GM slave
F#%K!!!
F#%K!!!
Thankfuly - No... When I first got under there I pulled the MC line thinking maybe it was leaking. Looked it over and hooked it back up. Still had the fluid coming out of the bellhousing. I was about two minutes away from pulling the tranny when I thought maybe I should check the bleeder. Never seen or heard of this happening.
