timing and octane any one want to talk
Old 07-01-2007, 06:15 PM
zrater's Avatar
Default timing and octane any one want to talk
about this, i would like to no alittle more about the two octane
timing tables can some one brief me on this .. 87 vs 93 can you
change the tables to run 87 , or no no .........................
Old 07-02-2007, 01:07 PM
NoGo's Avatar
The car references high octane for all points of normal operation.
When the car sees knock from the Knock sensors it will begin to blend the high octane values to the low octane values. Ultimately, if the car knocks enough you will run on the low octane values.
Additionally, alot of operation problems will default the car to the low octane table: MAF Failure, Knock sensor failure, etc...
I presume the low octane table should already be capable of running the car on 87 octane, but I have never verified this.
Old 07-02-2007, 04:47 PM
SSpdDmon's Avatar
The problem isn't always timing. Check out the octane post over on Wikipedia.com. When running a higher compression ratio engine, pressure can cause pre-ignition in a warm cylinder too. If that's the case, it doesn't matter how much timing you pull.
Old 07-02-2007, 07:00 PM
zrater's Avatar
well jack *** me , i pumped a whole tank of 87 and it was about 85 degrees out
and i did not reliz it till it was full, wooppps wrong car o f--k. well anyways
the car ping more than you could believe just touch the throttle, so i took
and went from 23 degrees to 17 on high side , and 15 on the low side, at wot.
and no kr at all . so what is this telling me, the car was down on power tho...
