MN12 in T/A, shifter problem HELP!
Old 07-02-2007, 01:53 AM
02 Blackbird's Avatar
Default MN12 in T/A, shifter problem HELP!
I just installed a mn12 from a gto into my 02 T/A. I put the shifter that was on the car when I got it, which is a pro 5.0. The shifter sits too far forward, makes it hard to get the car in 1st and reverse! Anybody have a problem like this? Will I need a different shifter? Any help will be much appreciated
Old 07-02-2007, 03:16 PM
Tootall's Avatar
there are "jam nuts/bolts" that need to be adjusted. There's one on the front and back of the shifter.
Old 07-02-2007, 09:43 PM
The bump stops???
Old 07-02-2007, 09:56 PM
Tootall's Avatar
Originally Posted by 02 Blackbird
The bump stops???
correct
Old 07-02-2007, 10:36 PM
ls1 joe's Avatar
No you have to remove the shifter cup and reverse reluctor to make it work. They are different in the GTO and the FB. You need to buy the fbody piece which will require using a punch, remove the old one, buy a new one and install it. Kind of complicated to do with the tranny in the car. Other than that you are always going to have issues. We do the conversions and I know for a fact if you don't change that piece you will tear up the trans.
Amber
Old 07-02-2007, 10:37 PM
ls1 joe's Avatar
The reverse reluctor is what the shifter cup sits in. In the GTO it makes the shifter farther forward. They are different but the bolt pattern for the shifter is the same.
Old 07-02-2007, 10:41 PM
DONAIMIAN's Avatar
The MN12 is NOT a direct swap. There are parts that need to be changed to make it work properly in and f-body. Dont drive your car untll this is done becasue chances are you will beark something. I dont know the name of the part, but its the part that the ball on the bottom of the shifter sits into. Maybe Joe or Amber can elaborate more on this.
Old 07-02-2007, 10:50 PM
Tootall's Avatar
this is a really horrible picture, but
Old 07-02-2007, 10:53 PM
Amber
Ok so i can use the same shifter, I just have to change the reluctor??? Do you sell this stuff? If so how much?
Old 07-02-2007, 10:56 PM
ls1 joe's Avatar
I have 15 I think. They are $25 plus shipping. Just call me in the am and tell me you are the FB to GTO guy. I will know what you need.
Amber
Old 07-02-2007, 11:01 PM
Amber
Ok, will it come with instructions? Transmissions aren't my strongest point obviously.
