Just got headers on, not runnin right
Got my headers on and she's ready to go. I took her for a drive and it was fine for the first minute or so. Then I was sitting idle for a few more minutes and the whole car started shaking terribly. When I started giving it gas (as I started moving) it got better, but a few seconds later it started bogging down real bad. To just drive normally, I had to give it half throttle. Every few seconds it was like something "clicked" on and I started to take off (like normal 1/2 throttle). Then it would bog down again.
I checked the plugs and wires thinking it was misfiring or I burnt up a wire, but they were fine. Is it running lean or what? It's an 02 LS1 A4, the headers are pacesetter LTs with the ORY. No other mods.
Originally Posted by 5.3LJimmy
do you have your oxygen sensors unplugged?
Also trans99am I would resize that sig before the mods get at it man!
The O2s were plugged in. I took the rear ones out though. After I drove it a bit more, it started running nice and smooth. I put 50 miles on it to be sure and it has run flawlessly since I posted this. Is it possible the sensors just had to calibrate to the new setup? I have no issues with it at all now. Thanks for the help everyone.
Well, it started doing it again today. Seems if I sit idle for more than 5 minutes or so, it starts it up again. Someone mentioned something about O2 simulators. What are they? Where do I get them? And is it something that would fix this problem?
You have to have your REAR O2's either tuned out or install sims on them.
Link to O2 sims
It sounds like its an O2 problem
Also, in you haven't yet read through the sticky at the top of the page
STICKY
Link to O2 sims
STICKY
If it only does it after idling for a while it may be temperature related, b/c the engine will run hotter sitting still. Maybe you damaged the coolant temperature sensor or the wires to it. It is located close to the front of the header flange on the side of the head, and could easily be damaged. If it's messed up it will affect air fuel ratio at part throttle causing the engine to bog or stumble.
