which after market EMS
Old 07-02-2007, 03:46 PM
7 Second Club
ty_ty13's Avatar
Default which after market EMS
i've decided i cant race on little tires and be able to compete with the capabilities of the stock pcm...
between the FAST, BS3, and AEM what EMS do you guys like the best... so far im deciding its BS3 or FAST but im leaning towards BS3.... more than likely this will be a winter project so im not down during the season but i need to make my mind up now and get it ordered ASAP so that i miss the late fall rush for parts...
Old 07-02-2007, 04:07 PM
Boostaholic's Avatar
BS3 has been a great system for me, I would buy it again if I was in the market for a EMS
Old 07-02-2007, 04:46 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I have BS3, and I think it's a very strong product, and also price competitive too.
Old 07-02-2007, 04:59 PM
kp
kp's Avatar
Main reason I'm using a BS3 is because PSJ is
But seeing it was designed around and LS1 and its all in box, AEM doesnt have a low-Z driver, DFI has a seperate coil driver box, not sure on the new XFI, I went with the BS3.
Software is a bit clunky but its simple and does what its supposed to do, ever since I put it in the car I havent had one bit of trouble out of it.
Old 07-02-2007, 05:23 PM
Josh@KY-Turbo's Avatar
Representing for the FAST XFI/XIM crowd here. Require 2 boxes. XFI box for the engine and the XIM for the ignition. Its come along way from the old days of FAST.
Cant go wrong with BS3 though. Its proven.
AEM is awesome. Used your Factory wiring harness and keep all the factory gauges. Dwownside is it is as expensive as the rest and you have to have a injector driver. It will be goiong on my next street car though.
Old 07-02-2007, 06:00 PM
6techniques's Avatar
Im with Boostaholic, PSJ and KP on the BS3 being a good system...No other brand can match its bang for the buck (unless you go DIY like the mega squirt) which is why Im going that route as well. The XFI is a good system as well if you dont mind adding a few more dollars, its also a very "professional" looking setup too.
Old 07-02-2007, 09:23 PM
edwardswb's Avatar
I nearly bought an XFI system today...it's nice-price is great, but I think I want to go BS3
Old 07-02-2007, 09:29 PM
LTLHOMER's Avatar
bs3 here. Same reason as the last thread about this a week ago.
Old 07-02-2007, 09:37 PM
Navy David SS's Avatar
AEM all the way. Controls everything. Last time I heard they were in the test mode for a plug and play LS1 box.
David
Old 07-02-2007, 10:22 PM
70Stang's Avatar
AEM - They have done tests, you know. Works everytime, 60% of the time.
Old 07-03-2007, 07:50 AM
LTLHOMER's Avatar
hahahaha
Old 07-03-2007, 10:38 AM
12secSS's Avatar
David
It is in production, and no seperate injector driver needed. It is a true plug and play, I think it retails for $1600 or so.
Old 07-03-2007, 06:31 PM
Last time I talked to the guys a AEM they told me I would have to have a injector driver box to run my 83lb Low impedence injectors. That their unit would only run High impedence style injectors. The was less than two and a half months ago. If AEM is a all in one plug and play that will run the Low impedence style injectors then I would very seriously conside selling my FAST setup to buy it. I used AEM on every one of the Mustangs I have built over the years and loved it.
Hmmm...
