have a few questions with edit
Old 05-09-2003, 11:00 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Default have a few questions with edit
well i got my ls1 edit up and running but i have some questions about tuning for fuel and timing there are so many tables.i would like to be on the right track the first time. my computer is set back to stock so my car runs like **** so i need a crash cource quick thanks. my ltft are +5 and my timing is at 40degrees at about 2000 rpm that sounds high compare to my old setup when i had 30degrees
Old 05-10-2003, 04:18 PM
tuff's Avatar
Default Re: have a few questions with edit
is high octane spark advance the correct timing table for adjusting my timing if so why is the stock timing setting set so high. its at 40 degrees wot. it seems like i would be taking timing out. need some help asap thanks
