Help-big injector bog off the line!!!!
Guys-i recently installed a set of 96lb injectors in my car and now i have one glaring problem. The car bogs off the line. All I did on the fuel tables is adjust the IFR table, multplied the whole offset table buy 90% and turn the fuel pressure down to 45 psi. It never did this with the 60's but it's doing it with the 96's. Any help would be greatly appreciated-thanks!
Originally Posted by eb02z06
If I wack the Throttle when the car is parked at idle it goes lean right after-I'll have to log it in drive and see what it does.
what #s did you input on your IFR? i assume your running referranced.
is the car running ok everwhere else?
Nick right now I'm trying a #86 swing per Slowhawks advice-that's up from a the #74 swing I had before. I am running referenced but boost only-I have a check valve inline and do not pull vacuum. The car drives fine everywhere else-it goes like snot-after the bog.
Well I went home at lunch to see what the AFR does. As soon as I touch the throttle the car goes from 14.5 to 16-17, so it's going lean. Could this be causing my stumble? Should I correct this in my VE table or my MAF?
thanks!
thanks!
thanks!
thanks!
Originally Posted by Slowhawk
I've been trying to get him to go SD for awhile now. He won't turn
Also what's the GM part # for the 3 bar map that plugs inot the manifold?
Thanks guys!
