Replacing clutch very VERY soon..few ?'s
My clutch is on it's way out. Can't grab 2nd 1/2 the time without it slipping till I lift off the throttle a little...anyhow it's getting replaced....
I'm a mechanic and have done literally hundereds of clutches in all kinds of cars.
On my 00 T/A is there any special tricks, hidden bolts or whatever that I may encounter? Or is this one simply as straight forward as it appears.
How many hours should a experianced mechanic expect to take doing this off jackstands?
Thanks
Thanks
getting the trans out and the clutch in doesnt take that long...its the exhaust, tq arm, and hydraulics that take time. the master cyl is a bitch to get out if youre replacing it...it has to be removed from under the brake booster.
i didnt unbolt the torque arm from the rearend so i unbolted the clamshell on the front and it was tough to get back together.
i disassembled mine before the parts arrived, but i'd say it chould be done in 1 day on stands if you dont mess around with stuff like i did.
read up on the install at www.installuniversity.com
Cool. Mainly conserned with tricky bolts and such. Sounds pretty straightforward.
I prefer to remove items if I even remotely think they're going to interfere. Seems to save alot of time and frustration.
I am amazed by how fast professional mechanics work. Nevertheless, on jackstands, replacing an f-body clutch the first time, plan to put in a long day. The service manual says to remove the trans and bellhousing together. That’s bad advice - remove the trans from the bellhousing.
well among other things you need a clutch line disconnect tool, also word of advise, from someone who has toasted 2 clutches in a car that has only 28,000 miles on it. get a new slave. and make sure it is the 01-02 updated version do not install a new clutch with out doing this, the new clutch will cause your old unit to fail really fast, also a remote bleeder is 80 bucks well spent. flush the whole system as well, dot 4 is best. 3 hours for a tranny removal, 4-5 to install, the torque arm is going to be the hardest part of the install.
Originally Posted by 99ssleeper
you dont need a clutch line disconnect tool. take 2 small screwdrivers and push the white ring on both sides until it is all the way into the slave cyl fitting. the line will pull right out. i did mine that way with no problems at all.
