newbie 6L accessorie swap question
What do I need to do to replace all of the truck accessories with F-body accessories? I have the part numbers for the bolts and brackets but I wanted to make sure they would just swap over. Would have to replace the water pump and crank pulley as well? If I change the accessories would the PCM and harness have to be swapped as well? thanks in advance
