i am doing my headers right now and have a ?
Old 07-03-2007, 06:08 PM
ROLLN's Avatar
Default i am doing my headers right now and have a ?
thanks to wireless i can be on here and in the garage.lol
#1 how to tell which way the header gasket goes on?
#2 i had my rear o2's tuned out so what do i do with them? let them hang?
#3 yay or nay on locktite for the header bolts?
#4 do i absolutly have to take the coil pack off on the passenger side?
thanks for any answers on these.
Old 07-03-2007, 06:16 PM
BayAreaSS's Avatar
1. You just have to line up the holes on the gasket and make sure they match the holes on the heads and headers.
2. Just ziptie the rear 02's to something under the car.
3.I didnt use loctite but i wish i did. I would use it.
4. Taking the coil pack off gives alot more room so i would just take it off and make it easier on yourself.
Old 07-03-2007, 06:31 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
#3 --didn't use it and never have for exhaust bolts....just re-tighten every once in awhile....if problem persists, your heads are not true...or use new ARP BOLTS which I do. WHAT GASKETS ARE U USING---ONLY METAL WILL DO.
Old 07-03-2007, 06:33 PM
ybaslo1's Avatar
2. If you have them tuned out, can't you just unplug them and throw them in a corner somewhere?
3. Don't use the red ****.
Old 07-03-2007, 06:46 PM
ls1_doc's Avatar
Yeah but he is using the old to plug the holes i am imagining. If you go to an exhaust shop they have 02 sensor plugs then you can that.
Old 07-03-2007, 06:50 PM
ROLLN's Avatar
i got metal gaskets and grade eight bolts
Old 07-03-2007, 06:52 PM
ROLLN's Avatar
my headers only have one bung which i beileve is for the front o2's. right? and on the gasket on one side, the gasket sticks out and vise versa on the inside.
Old 07-03-2007, 06:59 PM
BayAreaSS's Avatar
since you have grade 8 bolts you dont need the loctite. You can just take the rear o2's off. Since you're not using them.
Old 07-03-2007, 08:16 PM
TheSilverOne's Avatar
apply some anti seize to the bolts
Old 07-04-2007, 05:15 AM
staringback05's Avatar
you dont have to use locktite, zip tie your o2 wires, its easier to do things when the coils are off
Old 07-04-2007, 08:44 AM
HavATampa's Avatar
1. You didn't say what gaskets you are using, but stock GM gaskets do have a front and back, it's printed on the gasket, it says "manifold side".
2. Go to a local muffler shop and buy 2 sensor bung plugs. Zip tie the connectors out of the way after unplugging the sensors.
3. Nay, use anti-sieze.
4. Do your hands a favor and remove the coil packs.
Old 07-04-2007, 09:34 AM
vjjack04's Avatar
I just put headers on my C5 and found that if I put a small washer then a lock washer prior to putting in the header bolt that the bolts don't back out.
On a C5 you can pull the rear O2 sensors out and so you wouldn't have to tie them up.
The gaskets should be self evident.
