Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Dynoed my Z06, low numbers.
Old 07-03-2007, 06:31 PM
Venomystic's Avatar
Default Dynoed my Z06, low numbers.
Just got it dynoed yesterday on a DynoJet. It's 100% bone stock. I am a little concerned with my numbers, just wanted some opinions. The car has 6,400 miles, it's an 04. Conditions were, 92 degrees, 33% humidity. I put down 349/344 my first pull, 346/342 my second pull. (hp/tq) I thought they dynoed a little higher. Any input would help.
Old 07-03-2007, 06:47 PM
ls1 jeff's Avatar
You should feel good about those numbers. They are right in line with what an 02-04 z will dyno.
Old 07-03-2007, 07:01 PM
2MuchRiceMakesMeSick's Avatar
those are actually pretty good numbers. remember the 405 horse power rating is a flywheel rating and the dyno measures what the car actually puts down to the wheels after the drive terrain takes its portion.
Old 07-03-2007, 07:02 PM
chriswtx's Avatar
I agree those are good numbers...
Old 07-03-2007, 07:41 PM
Mike Mercury's Avatar
with a normal 15% driveline loss... that puts you almost exactly to 405hp.
Old 07-04-2007, 11:22 AM
Justin01SS's Avatar
Very nice numbers. MOD AWAY!
Old 07-04-2007, 12:06 PM
50_Dave's Avatar
Those sound about right. Mine put down 354/340 with a corsa cat back, and 365/357 with some tuning.
Hows the fuel to air on the car? We found the car to be running really rich.
Old 07-04-2007, 01:23 PM
DocT's Avatar
That's right where mine was. Nice mileage man! she isn't even broken in well yet!
Old 07-04-2007, 01:50 PM
Stol3n's Avatar
my 02z dyno'd 375hp/365tq with only a B&B Bullet Catback. Factory Tune.
Old 07-04-2007, 01:52 PM
06cobaltSS's Avatar
mine dynoed 348/340 stock.
Old 07-04-2007, 03:28 PM
DocT's Avatar
Mine was 350/335. Humid as crap and car was trying to overheat...Still, close to where they're supposed to be
Old 07-04-2007, 03:58 PM
King of the radial tires
Ranger's Avatar
Original poster's numbers are in the normal range, as many have written.
Two tip for those wanting to not show abnormally low dyno numbers.
(1) make sure your coolant temp is in the 190-194 range, not above, when the hammer is dropped in 4th gear on the dyno. That will take management of the temp and a cool-down between pulls. If the coolant is high, the PCM will pull timing.
(2) make sure you hammer the car through the gears some within a few hours of going to the dyno. Consistently low numbers get produced by owners whose cars rarely see WOT.
Ranger
Old 07-04-2007, 04:29 PM
DocT's Avatar
Ranger
I've heard from many people that the on board computers have a "memory" of sort that is profiled by the driver; that may be the reason for those who drive "nice and easy" are getting the lower dyno numbers, and those who tend to drive more aggressively will see higher numbers more often than not. I don't know any of this as a fact, but 3rd hand info. No matter, it still proves true.
RT
Old 07-04-2007, 05:39 PM
Venomystic's Avatar
Thanks for the info guys. I was scared for a sec, glad to see I made good numbers!
Old 07-04-2007, 05:50 PM
LS1 Freak's Avatar
Ranger
Dont worry, his car is hammered through gears all the time just like mine, we FL boys ride and play hard.lol
Old 07-04-2007, 06:42 PM
Azrael's Avatar
Here is my dynograph: 355 (354.6)/349 (348.95)
The first run with the lower numbers was with a misfire on 3.
