Dynamometer Results & Comparisons - low dyno results?
Hell'sChariot
07-03-2007, 06:52 PM
I had the car dyno about a week ago and I want to know what you guys think of the results. I think they are pretty low and the tuner even said he has never seen anything that low for the amount of mods done. The car runs great though.
Car: 2000 Camaro SS 53,000 miles A4
Mod list: TR224 cam 112,LS6 intake, 918 springs, ls6 oil pump, longtube headers, cutout, ported tb, ss4000 stall.
Results: 351.6 rwhp 341.6 rwtq open cutout
328 rwhp 331 rwtq cutout closed
The baseline run was 307hp and 317 tq.
Whats wrong with my car??
joedirtz28
07-03-2007, 08:59 PM
was the stall unlocked?
edcmat-l1
07-03-2007, 10:07 PM
DITTO
Your exhaust sucks too. You shouldnt loose 23 hp closing the cutout
Hell'sChariot
07-03-2007, 10:14 PM
nope, it was locked. I will try and find my sister's camera so I can post the dyno sheet.
Hell'sChariot
07-03-2007, 10:16 PM
DITTO
TRUTH!! :jest: my tuner said the same thing. He has never seen that big of increase from just uncaping the exhaust.
edcmat-l1
07-03-2007, 10:21 PM
I had one that was real low on power. We put a back pressure gauge in the 02 bung, it had almost 15 pounds of back pessure!!! Should only have about 1 1/2 pounds.
We dropped the exhaust and picked up 30 HP!!!
Hell'sChariot
07-03-2007, 10:26 PM
http://img71.imageshack.us/img71/3232/img065ex1.png
I scanned it. :)
makWS6
07-04-2007, 05:10 AM
What type of Dyno? I ran my tr224 on a mustang dyno and got 353rwhp/361rwtq no cutouts. Month later put her on dynojet and pulled 388/393 with no changes. All I know is I ran a 11.9 on the stock 10-bolt so I'm happy. :)
makWS6
Sorry, just saw it was on a dynojet.
melchoir
07-04-2007, 04:14 PM
That's definitely a locked graph, and should be 20 or so RWHP higher being locked like that. I made very similar HP numbers UNLOCKED.
Slowhawk
07-04-2007, 04:18 PM
You just have a low hp car.It happens.
john563
07-04-2007, 05:58 PM
when I was just cammed(tr224/112) with an A4.Thats about what I put down.I did not have cut outs though,but had dynomouth.My numbers were 349rwhp 355rwt.My car is a98
JaSSon
07-04-2007, 06:23 PM
My car dynoed 333rwhp with a TR224 and ran mid 11s so dont freak out just yet.
Hell'sChariot
07-05-2007, 10:43 PM
Im going to the 1/8th track tomorrow, I will post track times then.
MannyZ28
07-06-2007, 09:51 AM
My mod list is in my sig, for the most part. This was done through a Purolator paper filter...not like it makes much difference :lol:
http://www.homestead.com/mannyz28/files/dyno8.jpg
My car is a M6. What you are looking at is the difference between the first and ninth dyno pull after Mike Norris got his hands on the car. Interestingly enough, the last time the car was on the same dyno and got it's last tune for the cam, it put down 375/367 (those were STD numbers, not SAE....I posted the SAE version of the current graph, my STD numbers are in the sig). Nothing since then has changed except a cutout and 4.10 gears. I was in shock when the car laid down the low numbers it did in the first pull, quite frankly, I am still not quite sure what happened.
Seems like the only cars that consistenlty produce fairly low numbers with a TR224 or similarly sized cam, are 98 cars due to their shitty heads.
