fuel line at the fuel rail...
Old 07-03-2007, 11:31 PM
Yellowbrother's Avatar
Default fuel line at the fuel rail...
how do i disconnect it???
Old 07-03-2007, 11:36 PM
Phoenix 5.7's Avatar
fuel line disconnect tool. think its 3/8.
Old 07-03-2007, 11:37 PM
how does it look like??? where???
Old 07-03-2007, 11:43 PM
67rsss's Avatar
Go to Napa or other local parts store, ask for fuel and A/C disconnect set. Bunch of little plastic circles that slide on and release the tabs. Costs about $10 for a 7 piece set.
Old 07-03-2007, 11:57 PM
wtf??? damn that's expensive....any home remedy???
Old 07-04-2007, 12:05 AM
Andy1's Avatar
Try Harbor Freight. Not exactly sure of the price, but they were real cheap. Think my set was like $1.99 when it was on sale.
Andy1
Old 07-04-2007, 12:27 AM
sawzall wielding director
G-Body's Avatar
If your really really patient and careful it can be done with a couple small regular screwdrivers, but it is a lot faster, easier, and safer to buy the tool.
In a pinch you can make a tool by cutting open longways a piece of copper tubing and then closing it around the fuel line and using it to depress the tangs.
I think autozone might have the disconnect tools as free loaners.
Old 07-04-2007, 01:08 AM
the_merv's Avatar
You must not work on and mod your car that much..
And no there is no home remedy, you do not want to mess them connections up.
Old 07-04-2007, 08:32 AM
no...just that i dun wanna spend 10 dolla on something i will use only 1 time...
Old 07-04-2007, 08:40 AM
MY69camaroLS1's Avatar
Cut a plastic bottle rap around line and insert it in or a beer can will work.
Old 07-04-2007, 08:45 AM
67rsss's Avatar
The set will work for many connections on many modern cars. I fail to see how such an inexpensive set of tools is undesirable. You may be able to buy just the one you ned now for less, but the set covers a lot of different disconnects on a lot of different vehicles. Maybe someone in your area will loan you one? Hate to see you mess up a perfectly good connector.
Old 07-04-2007, 10:36 AM
69blackwidow's Avatar
dude you think 10 bucks is a lot of money, how can you keep your car on the road, wait how did you buy your car. lol
Old 07-04-2007, 10:42 AM
the_merv's Avatar
I just dropped $10 on a damn Brass Connector to extend my Alternator Cable for..oh yea..the $6500 I have spent for my new Engine project..so
Those little dis-connects come in very handy. I have the one that I need, it cost me $4.99.
Old 07-04-2007, 04:47 PM
Stu Cool's Avatar
Those connector tools also work on the Corvette Fuel Regulator Filter. I would not count on using it just 1 time, on a coversion project things tend to be put together and taken apart then put back together several times. I have the plastic set, then ended up springing for the anodized aluminum tool when I found it on sale. It works much better, but the plastic ones will do.
Here is a set for less than $6.
http://www.sjdiscounttools.com/lis37000.html
Pat
Old 07-04-2007, 04:52 PM
bczee's Avatar
You will also need one for the Hyd Clutch connection, so you many as well skip lunch or a beer or two for one day and just buy a set for $10 or so.
a few item that will need to tool for yours and other cars:
Fuel Rail
Vette Filter/Regulator
Clutch connector
Fuel Tank and return line.
Old 07-04-2007, 06:15 PM
67rsss's Avatar
Well, if you should damage the fuel line at the rail, I have the hose from a 2002 WS6 that I will be happy to sell you. Should run a bit more than $10 at the dealer...
Old 07-05-2007, 01:26 AM
Fuel Rail
Clutch connector
dunnoe y i would need tool for clutch connector since i eliminated the quick disconnect...keke...alos the fuel tank and return line ish just a tube...no tools necessary other then a screwdriver....
maybe i will use the tool more then just once...like 2 time initially and once a year after that...if that...damn...still would rather find a cheaper alternative...guess i'll dish out the 6 bux...
Old 07-09-2007, 10:24 PM
wildmanaaron's Avatar
The plastic ones have always given me trouble. I would get the metal tool. Tools to a man are like jewelry to a woman; there is never enough!
Old 07-10-2007, 08:03 AM
LS1GMCTruck's Avatar
Default Tool
I think I paid $4.00 at the local auto parts(Advance/Discount)for my aluminum 3/8"/5/16" combo quik-disconnect wrench. Gosh, you could do the same & then just return it. Just think of the money you'd save!?
Old 07-10-2007, 05:17 PM
kakakak...coworker has the tool...borrowed it from him...
Quick Reply: fuel line at the fuel rail...
