Backpressure Sensor ??
Old 07-04-2007, 02:49 PM
10secsts's Avatar
Question Backpressure Sensor ??
What are you guys using to measure backpressure? I'm not sure what kind of sensor can handle the heat.
Old 07-04-2007, 03:59 PM
stevieturbo's Avatar
Mount the sensor remotely, and any pressure sensor should do...
Old 07-05-2007, 01:33 PM
andereck's Avatar
You'll want to run a length of copper tube off of the exhaust, this will dissipate exhaust heat and then connect a rubber or silicone hose to this to run to a map or guage pressure sensor. An efi fuel pressure or oil pressure sensor should work nicely such as those sold by Autometer or others. They're usually .5 to 4.5 v and use a late tps pigtail.
Old 07-05-2007, 02:30 PM
1INSANEGTO's Avatar
Cool so I guess the oil pressure gauge I have will be put to use after all.
Old 07-06-2007, 09:03 AM
MIGHTYMOUSE's Avatar
i used a spare boost gauge, and made a fitting from a spare 02 sensor port into 1/8" barb for the vaccum hose.
