Egr?
Egr?
maybe i just misunderstood but on installuniversity. They remove the hose from your egr valve to your exhaust manifolds. Is it going to hurt anything if i remove the EGR valve itself or the hose that goes to the intake manifold and plug that also? sorry guys i'm confused as to why you can't remover those 2 pieces i thought you could
Sounds like you are mixing up the EGR and AIR removal process. The EGR is only attached to the passenger side exhaust manifold, not both. The AIR system is attached to both manifolds. If you remove either you have to plug the leftover holes. Read the stickies at the top of this forum for how-to's. Here's a few pics from the stickies.
EGR removed:
AIR removed:
EGR removed:
AIR removed:
Will just removing the EGR and AIR make the car run differently before getting a tune? I already have the "Service engine light" on from my cats being hollowed out. I plan on getting a tune in about a month. I just wanted to make sure thecar is going to run fine until then.
Also, do I need to order the block-off plates or do you creative guys have an alternative method?
