Special Edition Vehicles - SLP exhaust: replacement part ? (!Dave Hamburger!)
99'CajunFirehawk157
07-05-2007, 12:36 PM
My car of course came with the SLP added exhaust, one of my pipes is crushed pretty bad, can I get a replacement part for this system thru SLP?
Dave Hamburger...?
my1973form
07-16-2007, 09:34 AM
Which pipe is crushed? I have seen I-pipe on E-bay brand new, need more info...
99'CajunFirehawk157
07-16-2007, 11:05 PM
I would say this pipe is a lil crushed (?)...passengers side where the pipes go over the panhard
David Hamburger
07-17-2007, 07:38 AM
The OEM replacement intermediate pipe is still available: http://www.slponline.com/view_product.asp?P=10168S&BIG=10168S-1
Regards,
Dave Hamburger
99'CajunFirehawk157
07-17-2007, 12:41 PM
Thanks DAVE...!!
Camaroholic
07-17-2007, 01:18 PM
That's not the right pipe though.
The pipe in the picture is the over-the-axle pipe. It is not the intermediate pipe.
I've been looking for an SLP o-t-a pipe as well, there are none around that I can find.
The closest I found for me was a Dynomax / Walker 3" mandrel bent aluminized O-T-A pipe, but it's not designed for a center entry muffler (which is what I want), it's designed for an offset entry muffler. I think I can make it work, but it's a kludge (and not stainless steel).
my1973form
07-17-2007, 02:31 PM
The intermediate does go over the axle, and it is the "intermediate pipe" the intermediate pipe is between the muffler and the Y-pipe. Only 3 sections of pipe from the cats back, Y-pipe, I-pipe, muffler, tip.
Camaroholic
07-17-2007, 04:40 PM
The factory intermediate pipe is one piece.
The SLP replacement part is not. Look at that picture that Dave linked to. It will not go over the axle. That is the intermediate pipe. They used to sell the o-t-a pipe, but they don't any more (that I can find).
The SLP part above hooks to the Y-pipe at the front (where it necks down), and then it ends right before the axle (the bend in that pipe). The over-the-axle pipe starts right there (after that one kicks "up"), and then goes over the upper panhard and in to the muffler.
jimmyblue
08-13-2007, 03:34 PM
The axle-bend on the aftermarket exhausts is crushed, all
of them are like that, I guess that's the only way they
could get the radius in stainless. It is not significant to
flow, it's biased to the outside anyway centrifugally,
fuggedaboudit. Though I don't think mine looked quite
the same (CME, '02) I would leave it be, it's a very small
restriction in the big scheme of things. If you want to
get crazy, weld on a stud, get the O/A torch out and
hot-pull it flat (someplace well away from the plastic
gas tank....).
