what do you think it will make on HP
I am biulding a new kit for the firehawk shooting for 1000hp will i get it
364 6.0l block 8.5cr
scat rods
stock crank
disc pistons SRC
stage 3 heads
mls head gaskets
PG springs 650 lift
comp cams 238/236/648/618/115
90mm fast tb,arron elbow,gmmp intake
12x24x4 fmic 3"in and outs
2 mp t 70s .68 ar 3.5 down pipes
60mm wastgate
ls1 edit stock pcm
boost cooler methenal injection
gonig to run 10 psi on 91 on the street and 18 psi on 110 race gas
hoping to get 850 on the street and 1000 on the race gas tune
do you think i can do it
scat rods
stock crank
disc pistons SRC
stage 3 heads
mls head gaskets
PG springs 650 lift
60mm wastgate
ls1 edit stock pcm
In my opinion, you can make it I don't think you will get there on 18 psi...in a perfect world 14.7 psi will double you horsepower and I don't think your combo will yield 450-500 rwhp N/A, but I hope it does. look at pro stock john he is running 26 psi and making 850ish....this is my opinion but I'm stupid....
I so you think that i am going to have to run 26 psi
i made 706 hp on my 347 at 12psi on a pt88 kit i made I think that 20 psi will get me there the mp t70s are rated around 800 hp so the turbos will support 1400hp think i 1000hp sounld be to hard
Input
Talk to Tiago or Boostaholic, you will DEFINATELY need more that 50lb injectors - I suggest the siemans 96lb - my car idles just fine on them (2.0ms pulse), but 1000rwhp is not out of the question (may need a little more boost through), in case you were debating getting the 0.96A/R, I'd say stick with the 0.68 for the road, on my setup they are laggy (check sig) - just ordered a set of 0.68 to help the spool. Also, you do not need 3.5" downpipes, two 3" will be fine for 1000rwhp.
I have be waiting to her for some one running twin mp t70 to see if the hp they made is what i am looking for with them. Is your car a daliy driver oh are the MPG city and highway if you have more info on your car i would love to here more thanks wicked 1
