name that harness [help needed]
i didn't label where/what i took off very well...so now i'm in process to putting it back...there's bout 10 or so plugs that i'm not exactly sure where it goes...i will in the mean time also...so if anyone knoes wat/where each plug should go plz advise me of so...or lead me to where i can find the info...appreciate anyone's help....
these two are on one group of flex tube...
is this one with the blue rubber for o2?? don't have o2 in my hand so can't vfy...
does this one go into the 6sp tranny??? i have the tranny off so i can't vfy...
these are closer to the red/blue plug to pcm
The first one def looks like an O2 sensor and I think that you are right on the trans plug third one not sure fourth I believe is the plug that went into the airbox and fourth look familier but not sure right now
there's quite a few of these o2 plugs....anyone know how i can tell which one is which??? i'm trying to avoid from opening up the flex tube and tracing it back...i check the faq and only see the wiring output from the red/blue connector...not the individual plugs themselves...
Well, here are some pics of a few of the connectors on the 02 LS1. These are what I could get pretty quickly. I don't have anything like your third picture. I could not get any tranny connectors, the Crank sensor, CAM sensor or either O2. I have everything else....
AC Connector
Driver side Coil
Alternator and Temperature
Air Temp
Knock sensor
MAF, TPS and IAC
Oil Pressure (you don't need this one)
Pass Coil
Hope that helps....
AC Connector
Driver side Coil
Air Temp
Knock sensor
MAF, TPS and IAC
Pass Coil
Hope that helps....
AC Connector
Driver side Coil
Air Temp
Knock sensor
MAF, TPS and IAC
Pass Coil
Hope that helps....
AC Connector
Driver side Coil
Air Temp
Knock sensor
MAF, TPS and IAC
Pass Coil
Hope that helps....
oh btw...the harness is from a 2000 camaro 6spd....next time i take the harness of again i'm going to take a pix of the whole thing and label what i knoe each one is so maybe it can help others in the future....
Good idea. I know that when our car goes in for paint and body, we are pulling the motor and trans for detail work, and plan on completely documenting the harness. It should make repairs/mods much easier in the future...
Oh, does your second pic in the first post have grn/brn wires? If so, that is your backup lamp switch on the pass side of the trans.
yeah...it's green and something dark...either brown or black...
and the 3rd pix from first post that no one doesn't seem to knoe wat it is yet ish in a bundle very close to the blue/red connector...here's hopefully a better pix...
ok....so i sent to tinker with the harness again...found the map and cam plugs....too dark to find the crank...
these two plugs here appears to be an interior plug...becuz they are on a pigtail and has a rubber gromet in the middle of the pigtail....maybe this may help someone on here identifying this for me...
check out this site bro... just scroll down and it has a numbered layout of the wiring harness and what each plug goes to. also has what color every connector's wires are.
ls1 M6- http://www.hotrodlane.cc/Instruction.../InstalT56.pdf
ls1 A4- http://www.hotrodlane.cc/PDFFILES/ls...icharness2.pdf
1. 02 SENSOR
2. HARNESS TO CAR UNDERNEATH THE GLOVE BOX
3. TPS CONNECTOR
4. PASSENGER SIDE WHEEL WELL.
Should be another one there also..and a 10g Purple Wire with a Plug.
5. GRAY ON IN THE BACK-MAP SENSOR
BLACK ONE- CRANK POSITION SENSOR
i found a similar pdf from s&p while searching....not that one in particular....thanx...also while searching i found out the name of those two plugs are c220 and c230...
Originally Posted by the_merv
1. 02 SENSOR
3. TPS CONNECTOR
3. TPS CONNECTOR
The White/Blue ones under neather the Dash are names the C-220, and C-230.
The ones on the Wheel Well are named C-100(10 pin black), C-101(10 pin gray), and C-105(8 pin black).
by any chance u knoe or have documentation to the function/pin-layout of these connectors???
Just plug it in to where it goes on the Car..or are you doing something custom.
wat do u mean??? where else would it go in the car other then the ignition switch???? i guess it would be custom since it's a hybrid...
