Will this work???
Will this work???
Buying two separate DMH 3" electric cutouts from Speed Inc. Because they dont have a thing that says dual electric cutouts. So i was thinking that i would have two switches when i only need one. As many know, DMH's site is down, so i cant buy it from them. Only reason i dont want to go QTP is because of the lack of warranty.
What should i do?
What should i do?
well just wire the switches in series, creating one switch that will operate both units. I believe that is a six pole switch that comes with the unit, just trace your wires from one opener, and add the wires from the other opener to their 2 respective poles on one switch and you should be good to go. Also I am not familar with the DMH cutout's switch, but qtp's is big, if your looking into mounting in an ash tray or hidden area, you need a dual pole switch that is not momentary, ie something exactly like nx's remote opener switch, it is nice and small and allows flush mounting, I nice option for you.
