HELP ! car wont start after ls6 intake
after 6 hours of pain,scratches and wounds I installed the ls6 intake, now the car won't start , I start it up and it dies it doesnt start no matter what.
I broke that ugly thing behind the intake and I'm not sure if the car doesn't start because of it !! and I don't know what the hell is it
next time I would waste a lot of money than wasting time and breaking things !
check attached photo
Originally Posted by lastcall190
Make sure brake booster line is firmly reattached. I made the same mistake with same results. Good luck.
-J
-J
see attached pic, was it the same thing ?
heh...just a couple of threads down somebody else has the same problem. The part numbers for the replacement part is posted in there too.
https://ls1tech.com/forums/generation-iii-external-engine/744250-engine-sensor.html
Originally Posted by HavATampa
You broke the oil sending unit. Common thing to break on a manifold swap. The line lastcall is referring to goes from the back of the manifold to the brake booster on the firewall. Massive vacuum leak if you left is disconnected. Here it is:
thanks for the pic bro, I'm gonna check it out.
Originally Posted by mnypitZ
Looks like the oil pressure sender, but I am not sure that will cause it not to run. Mine was allready broken when we pulled my intake and it was running fine before.
Originally Posted by vaticano
i only say it because i did it but check the maf plug i put mine in upside down doh and it would'nt run
Ohhh totally man. If you didn't torque down the manifold in the correct sequence you'd get just enough of a vacuum leak to cause your problem. Good call on whosever part it was that called the call of torquing in correct numerical procedure.
