Alittle MAF advice please
Well if you dont convert to an 85mm, I think almost any maf off a gm v8 from 98-06? will work. I didnt have a maf for my 05 LS2 and it had the same part number as a ls1 maf.
Someone has told me to use the zo6 MAF. I'm not sure how big it is (85mm?) but it will (should)work with some minor tuning. It should allow me to drive the car to get to the shop where the tuning will take place. I will need a adapter to change from my MAF 98 harness to the MAF ls6 harness. I think it just plugs in between the existing maf plug and the zo6 maf....?....
Does this sound right?
Here is a list of all the vehicles that use this MAF GM Part # 25318411 AC Delco 213-364 http://198.208.187.182/internet/Vehi...sel=A&pageno=0
The part # for the LS6, (Specifically the 2002 LS6 (Z06) is 25341604....
http://www.gmpartsdirect.com/results...umber=25341604
Local dealer is matching prices with Flow Chevy on this part. Yeeehaw!
ChrisP
So a new lid is not in order. Well now that I went to the SLP website and saw their installation instructions I see what you are talking about. The vision in my head has a "rigged" look with the hose on either side of the MAF. Are there two worm clamps used with the additional tubbing (one on the input of the MAF and one on the lid output?
Originally Posted by vaticano
i dont recall the stock set up but you can just use another piece of large rubber tubing i have two on mine one on both sides of the maf
