Florida Members Fun, sun and LS1's
Lots Of Chevy Motors And Parts !!!
Old 07-06-2007, 03:27 PM
holley505's Avatar
Default Lots Of Chevy Motors And Parts !!!
Starting with the ENGINES....
COMPLETE BRAND NEW IN THE CRATE GM LS7 ENGINE
Chevy LS7 454 with 510 horsepower and 490 ft-lbs of torque. $5,750 oBo (this motor can make well over 650hp with right headers intake and carb)
NO SMOKE... good compression on these engines !!
1976 bone stock running 454 with all the accessories $1500 obo (pan 2 carb)
1973 bone stock running 454 with all the accessories $1700 obo (pan 2 carb)
1974 bone stock running 454 with all the accessories $1600 obo (pan 2 carb)
steal sbc 350 crank balanced to 10,000 rpm $275 Firm
sbc short block complete 4 bolt main... virgin bores $200 obo
sbc bare block with 4 bolt mains... virgin bores $100 obo
Several different small and big block performance INTAKES (single and dual) and factory performace intakes.
Used BBC exhaust manifolds, factory HOLLEY carbs and Q-jets
ALso.. SEVERAL 409 and 348 chevy parts including tri-power and dual quad set ups.
I will try to catalog all the other stuff and take pictures.
This is HUGE Collection of good parts being sold off by a GOOD FRIEND of mine. Let me know.... all the parts are in Central Florida. I can ship.
Old 07-06-2007, 03:50 PM
MPHmotorsports's Avatar
Disregard the PM, I can read from time to time.
Sorry.
Thanks
Old 07-06-2007, 07:01 PM
Jpr5690's Avatar
A New Ls7 For 5k ???? Also Its A 454?
Am I Missing Something?
Old 07-06-2007, 07:06 PM
Jpr5690's Avatar
U Must Mean An Old School Ls7 From The 70's
Old 07-06-2007, 11:18 PM
92slowmaro's Avatar
if its an old school motor its an ls6 not a 7.
Old 07-07-2007, 07:38 AM
holley505's Avatar
If you LOOK up your Chevy History... GM did make a LS7 454 BIG BLOCK ! Based on the Infamous LS6 Chevy engine from 1970. This is a GM reproduction of that engine these had been reproduced in the early 1990 for a limited run.
BASICALLY every BAD-*** big block part the general produced on a stock displacement 454....YOU COULD ACTUALLY buy this motor over the counter in the early 70's
Think the ZL1/L88 (which is a BAD *** 427)
GREAT for Drag Racing...
Old 07-07-2007, 06:47 PM
holley505's Avatar
The LS-7 crate motor definitely was available until its discontinuance(along with the LS-6) sometime around '90-'91. It had 12.25:1 compression and the (solid lifter) cam specs were 262/273 dur. at 0.050, with lift at .580/.620. The blocked would've been stamped XCH.
Old 07-09-2007, 01:02 PM
holley505's Avatar
more specs
PN 3965774, 454CID, 12.25:1 compression, 4 bolt main block, 5140 forged steel crank, w/cross-drilled mains 3963524, 4340 forged steel connecting rods with 7/16 in. bolts for pressed pins, 3963552, forged high dome pistons, racing mechanical camshaft 3959180 (same as ZL-1), open chamber cast iron heads 6260482, balancer 3963530, standard flywheel 3993827, engine suffix XCH.
Quick Reply: Lots Of Chevy Motors And Parts !!!
