Drag Racing Tech - qa1 and stock spring ?
bowtierodder
07-06-2007, 06:30 PM
the front qa1's R series can be used with the stock spring correct? i was getting ready to order and wanted to make sure :)
WS6TransAm01
07-06-2007, 07:13 PM
Yes they can, I have stock springs on my QA1's, but you need to buy either an modified stock spring cup of one of the billet pieces from BMR or similar.
Nine Finger 02 Z28
07-06-2007, 07:19 PM
Yes they can, I have stock springs on my QA1's, but you need to buy either an modified stock spring cup of one of the billet pieces from BMR or similar.Nice to know...Thanks
bowtierodder
07-06-2007, 08:19 PM
ive heard you can modify the stock spring cup...anyone know how?
WS6TransAm01
07-06-2007, 08:43 PM
I don't know the exact measurements but what you need to do is remove material from the center until the resulting hole is the same diameter as the new shock tube.
PS im posting from my iPhone in a parking lot, aint technology awesome!!!
bowtierodder
07-06-2007, 09:03 PM
:) this site was one of the reasons i even thought about getting one, how do you like it?
as for the spring cup.... that seems fairly easy to do, and ill save some $
6techniques
07-06-2007, 09:06 PM
do it and post some pics up, Im curious about this as well.
bowtierodder
07-06-2007, 09:15 PM
will do
CoopDog
07-06-2007, 09:57 PM
I run the stock perches on QA1 shocks, it has worked well like that for 6 or so years. It is correct that all you need to do is remove some material and make the inside diameter larger. I believe I used a die grinder to do this. A word of advice, get the thrust bearing kit with the shocks, it is almost impossible to make on car adjustments without them.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
