Fk'd Up Prothane Motor Mounts???
Well we installed my new Erik built 408 yesterday, the heads and balancer were on, so we had to use a shoe horn. The motor mount bolts went in no problem. Put on the flywheel, pressure plate and scatter shield. The drivers side header went in no problem. Passanger header would no way, no how go in, we tried for a 1/2 hour.
It turns out that the engine is badly misaligned, with the rear of the engine being about 3/4" too far on the passanger side. After checking the new UMI K member and finding no problem, we notice that the motor mounts have a bias of about 3/8 of an inch that is causing the motor to be skewed. It appears that Prothane instead of sending me separate left and right poly inserts sent me either two lefts or two rights. I am really fking mad.
No way would the mounts work correctly, so we had to take everything off the engine and take the engine out. Pissed.
Has anyone had any experience with these motor mounts?? Any help would be appreciated.
OK, if you guys have installed them maybe you can clear up a few questions. First I assume that the the small gold tabs have to go on the top of the K member mount. If this is correct then with the mounts I have there is a bigger gap on the front of the drivers side mount than on the passangers side mount. This shifts the rear of the motor to the passanger side and absolutely won't let me install my header. It hits the heater box, kmember mount, etc.If you have any ideas I need them. Thanks.
im pretty sure i read that you have to put a spacer in the side that had to much space for the engine mount. and you may want to try moving this to the suspension and brakes part of the forum they will be able to help better
I just talked to Prothane, they claim each side takes the same poly insert. If that is true then the UMI K member is misaligned, which I find hard to believe since I think the UMI products are excellent. I spoke to UMI also and they can't figure it out. I ordered in some OEM motor mounts, so I will be able to tell from them whether it's the Prothanes or UMI member. In the mean time if anyone has any input I sure would appreciate it.
OEM motor mounts are going to have more play in them than the poly's will. Just because they fit doesn't mean that your k-member isn't off. I'm not familiar with the UMI k-member though, do you still use the mount stands? If yes, could one of them be bent or mis-aligned?
The mount stands may be the issue. If after I compare the OEM motor mounts to the Prothanes and they match up exactly, then the only thing it can be is the K member, and or, the K member mount stands. I really hope that's not the problem, because it's alot of work replacing the K member since the A arms, brakes, rack and pinion, etc are already installed.
It turned out that the Prothane mounts were manufactured incorrectly. The metal inserts that are molded into the poly normally stick out more on one side than the other, well the prothanes had the longer part on the wrong side, thus throwing off the complete engine alignment. They sent me replacements after I convinced them their product was in fact faulty. Had I only replaced the motor mounts and not the k member and motor then determining what was screwed up wouldn't have been so difficult. I just hope some other guys didn't install some of these fkd up mounts.
WTF.
i had this same issue on my drivers side. when i went to install the drivers side header, it was hitting the drivers side motor mount pedestal, causing the header bolt holes to not line up. just a fraction of an inch off!
i guess it could have been the passenger side causing the issue on the drivers side tho.
how did you check motor alignment?
also, how do you contact Prothane? their website isnt available now.
Did you guys get your issues worked out? I feel for you. Google Prothane and you can get a # from their site. Once I convinced them that they were at fault they didn't give me any more ****. Trust me they know what has happened because I sent my motor mounts back to them on my dime. It really is a great inexpensive mod if you don't have problems.
Wow, this sucks for you guys, I put prothanes in last year and they went in great and the engine sits fine. At least you could convince them that the mounts were defective and gte some new ones.
Mine went in just fine. Both sides are the same, but they can be put in backwards. It could be that the kmember is off, or the mounts might just be backwards. Mine made header install easier because it lifted the engine up significantly over the origionals.
Maybe your header is off. I have had poorly made headers not fit before.
just a thought.
John
just a thought.
John
