Temp and Oil sender question
Old 07-09-2007, 03:04 PM
dream1q's Avatar
Default Temp and Oil sender question
I have the pigtails for both the senders, my question is really simple. The oil sender is a 3 wire plug, other then the feed, what are the two wires running to?
Same with the water temp, its a 2 wire, where is the second wire going, ground?
BTW.....this is for my carclubs Pinks car. Should be there the same day you guys run yours in KC
Help please.
Old 07-09-2007, 08:37 PM
sawzall wielding director
G-Body's Avatar
What year LSx, truck, car vette, or gto wiring?
Based on the temp it is 99 or newer wiring. The temp sensor is serial data, effectively a sensor wire and a ground.
I am not sure about the oil pressure, all the diagrams I have seen are single wire, maybe GM updated the later models to a 5v reference oil pressure sender? Ground, 5v reference power, and sensor output?
Old 07-10-2007, 06:06 AM
RE AND CHERYL's Avatar
The oil press sender runs both the oil pressure gauge and also supplies a ground to keep the fuel pump going after the engine starts. The 99-02 F-body temp gauge runs to the PCM only. From there the PCM sends a serial signal to the gauge cluster. You can't eliminate either sensor.
What are you installing the LSx into?
Re'
Old 07-10-2007, 10:04 AM
dream1q's Avatar
Motor is going in a 88 Mustang.
Got the temp working, just used the driver side hole in the head and a 6 liter sender. Ground and signal to gauge.
But the oil is giving me fits. It is a 5v reference, but I cant get it to do anything but peg the gauge when I fire it up. I picked up 5v off of the IAC, ground to the firewall, and signal to the tach. I'm about ready to use the hole by the filter and put a new sender in.
Quick Reply: Temp and Oil sender question
