MAP sensor extention harness
Old 07-09-2007, 10:26 PM
eb02z06's Avatar
Default MAP sensor extention harness
Guys-i'm swaping over to a 3 BAR SD tune-does anyone sell a MAP sensor extenion harness that's plug and play and allows you to use the older GM style 3 bar MAP sensor. Also does anyone have the correct GM part # or is the FAST 3 bar map offer better resolution-thanks!
Old 07-10-2007, 09:37 AM
SSpdDmon's Avatar
As far as I know, the loss in resolution is in the PCM, not the sensor.
Try calling Casper Electronics for a harness/extension/connector.
Old 07-10-2007, 04:08 PM
cablebandit's Avatar
i think i got my harness from livernois or speedengineering
Old 07-11-2007, 03:29 PM
NoGo's Avatar
I'd stick with what is an easy install.
FAST 3 bar map sensor (from Speed Inc.)
FAST map pigtail (from Speed Inc.)
