header install advice. please head
Old 07-10-2007, 02:34 AM
02NMBZ28's Avatar
Default header install advice. please heed.
do not, under ANY circumstances, use the 10mm header bolts supplied in the packaging from Jet-Hot. They round off as you torque them down costing you hours as you slowly back them out with vise grips. that is all.
Old 07-10-2007, 05:30 AM
Tainted's Avatar
should have done your rsearch and you would have known the stock botls are fine to reuse or upgrade to ARP's or the grade 8 lockers
Old 07-10-2007, 04:43 PM
Pewter02WS6's Avatar
I used the stage 8 bolts but didn't use the lockers. Very nice and they match the coating on my pacesetters
Old 07-10-2007, 05:27 PM
lastcall190's Avatar
I'd do the ARPs or reuse stock bolts before touching another set of Stage 8s.
Old 07-11-2007, 01:08 AM
TwistedSS's Avatar
Stock bolts here...no probs at all
