A4 shifter handle and console removal questions...
Old 07-10-2007, 12:15 PM
99'CajunFirehawk157's Avatar
Question A4 shifter handle and console removal questions...
I would like to take my a4 shifter handle off and my console out to check some things, how hard is this to do?
PLMK
Old 07-10-2007, 12:24 PM
kaos_'s Avatar
get a screw driver flat head and pry out the staple behind the shifter, lift it off, unbolt all the bolts in the console compartment (4 i think) and the upper part should lift right out. then there are a few more bolts holding down the lower section. put your shifter in 1st gear and the parking break up to make it easier to lift it all out.
Old 07-10-2007, 06:36 PM
Default So, uh...
Uh, staple...really??
Old 07-10-2007, 07:55 PM
WS6NIGHTMARE's Avatar
Not really a staple, more like a C clip, but you get the idea.
Old 07-10-2007, 08:55 PM
Copy & Paste Moderator
VIP1's Avatar
In the front of "tail" of the the shift **** (facing the radio), there is a slot with a staple just like WS6NIGHTMARE said. Pry out the staple and pull the handle up to remove it.
Old 07-10-2007, 09:36 PM
shaZZam's Avatar
Put electrical tape around the E-brake handle before you pull the console up, or you will scratch the **** out of it.
Old 07-10-2007, 10:43 PM
Thanks guys, good info.
Old 07-11-2007, 05:57 PM
Formula413's Avatar
Also, if you have a coin holder in the compartment in the console, take it out because there are two screws under it. Sounds obvious, but dumber things have happened.
