what is this? exits int mani
felt i had to start a thread because i keep asking in other threads with no response.
what is theis "valve" like thing?
it exits from behind the throttle body and wraps around the driverside of manifold into a valve-like thing. then a fuel hose is connected to it(which is cut on my engine)...
http://i2.photobucket.com/albums/y47.../fuelpiece.jpg
ive seen it vented, but the one on my 98 is cut cro-magnon style and im it might need to go to something important
thanks in advance
thanks in advance
ok cool.
two options?:
1. remove and plug it (since it is tuned out of my pcm already)
2. remove it and run a hose from my fuel vapor line to the hole in the mani.
i think ill plug it and vent the fuel tank to atm
thank you greatly
two options?:
thank you greatly
Originally Posted by bczee
I used the manifold port and fuel tank vent into a Charcoal Canister that will then suck the fuel from the Fuel tank. That way you will not get fuel flumes while parked inside.
We capped the barb, and our stainless tank is not vented. We capped the little fitting on the tank. The cap is vented. Everything seems to work fine, no fumes, and no weird hissing when we pull the gas cap.
Originally Posted by natedawg
which end do you have to "Cap" the throttle body?
BLUE is the hose that goes to the Evap Purge Valve.
RED is the Evap Purge Valve that i removed (tuned OUT of PCM).
YELLOW is where "MMDB" vented his Evap Purge Valve.
Courtesy MMDB, ls14 build thread.
the area between the header and the intake filter (kind of open area) Is where my S13 Charcoal Canister was. NOW its an atm-vented line.
Last edited by NismoSilvia270R; 07-11-2007 at 11:42 AM. Reason: forgot to mention vapor line
