Generation IV External Engine - 402/L92/L76... Looks like crap!!!!!
fastbasser
07-10-2007, 01:47 PM
I recently had a new motor installed.. A 402 with ported l92 heads and the L76 intake. I have Ford 42 lb injectors so the fuel rails are spaced up...Runs great!! Looks like crap! IMHO
Does anyone have ideas as to what can be done to improve the look under the hood of my C5? I mainly looking for engine components.. I have thought about a sheet metal intake and billet fuel rails. Another thing is the MSD coils and have the coil brackets powder coated.
Fuel rail covers dont fit... Who sells sheet metal intakes?? Fuel rails??
Any ideas will be appreciated.
Thanks for the assist!
:drive:
See5
07-10-2007, 02:05 PM
We just did this is a stealthy LS7 with L92s, L76 , SVO 42s and LS1 fuel rails. BTW it made 529/530 RW .
http://home.new.rr.com/meltn/ARLS7.jpg
Black FormulaLs1
07-10-2007, 02:22 PM
if you look around you can get the fuel rail covers and intake and stuff like that airbrushed ask around about truefire....the guy that does that would certainly clean up your engine bay!!!! and the rest of us would be extra jealous lol
JoeyGC5
07-10-2007, 03:18 PM
:drive:
Out of curiousity, why didn't you use the stock L76 ijectors?
RGKSR
07-10-2007, 03:25 PM
I used the stock L76 injectors and used the Kateck LS1 harness to injector adapters. I'm also looking to get the top end pretty again.
Bob K.
WizeAss
07-10-2007, 06:35 PM
need some input on what hookups... we are putting the motor in my car this and next week.
Offset rockers, need new intake rockers and pedestals. I have SVO 42lb injectors.... but they where already made to fit my GMPP intake..... I am using my stock harness. What else should I worry about? Anything out of the ordinary?
Sharpe
07-10-2007, 08:07 PM
:lol:
You're wishing the Gen III/IV engine bay could look as good as the Gen I. Doubt that's going to happen 100%, but you can make them look good, even real good. There's nothing like looking under the hood and seeing next to nothing but engine. In the C5, you're just about out of luck.
The F-Body has some hiding places. People relocate the coils to under the cowl, the computer into the fender well, etc. I'd direct you to the huge ass engine bay thread that has some knockout pics, but it's almost all F-Body.
I'd start a thread in the Appearance section or on Corevetteforum with the title "Post the Best Looking C5 Engine Bays." That might get you some ideas.
Good luck.
KOOL C5
07-11-2007, 04:32 AM
I just did new valve covers from ABEAR on my 97 C5 LS7. Hide the coils with the enclosed covers.
http://www.abearmotorsports.com:80/
WKMCD
07-11-2007, 06:04 AM
Here's a good looking 403/L92/L76 engine. :D
http://i54.photobucket.com/albums/g93/WKMCD/engine.jpg
KRAZY K 2000 TA
07-11-2007, 11:22 AM
love those valve covers
fastbasser
07-11-2007, 06:05 PM
I guess the shop that did the work did not have the adapters for the injector wires. I may end up buying the adapters and going back to the L76 injectors.
edcmat-l1
07-11-2007, 06:21 PM
Sure is purtey!!^^^^
VortechC5
07-11-2007, 08:39 PM
Here is mine:
http://cfupload.stevesdomain.net/images/b61ca46ac0.jpg
1bigcam
07-11-2007, 09:23 PM
here is mine
http://i209.photobucket.com/albums/bb253/2000jeep/michealsspace001-1.jpg
fastbasser
07-12-2007, 06:48 AM
Those are all very impressive!! Where are you guys getting the valve cover, fuel rails and brackets from?
Thanks for taking the time guys!
:drive:
SUTTERERMAN85
07-12-2007, 12:10 PM
ill try and post some up of mine tonight. i am using green tops and some $55 Prof. Products rails and Katech spacer kit.
Quik
07-15-2007, 10:24 PM
http://i172.photobucket.com/albums/w17/Quik79/Truck/truck005.jpg
http://i172.photobucket.com/albums/w17/Quik79/Truck/truck004.jpg
heres vette covers on a L76 setup with svo 42s
the_merv
07-15-2007, 11:29 PM
You guys have some nice setups. I plan on getting mine in this week, I'll post some pics.
99NMB
07-16-2007, 01:16 AM
that is f'n sexy... i have a new wallpaper now... :)
WKMCD
07-16-2007, 05:47 AM
Thanks. I need to get some new pics in the light. I've cleaned up the wiring and SS lines since this pic.
BTW: Runs strong also! :drive:
SUTTERERMAN85
07-16-2007, 05:03 PM
http://memimage.cardomain.net/member_images/7/web/2155000-2155999/2155116_35_full.jpg
not as pretty as everybody elses but it works.
98C5LS2
07-22-2007, 07:07 PM
Where you able to tweak the LS1 mounting tabs on the rails enough? Or did you use offset standoffs or something?
Thanks.
See5
07-22-2007, 07:31 PM
Thanks.
Tweak and ~1/2" spacers made from tubing. Really about a 1/2 hour job. Done more than a few.
mike c.
07-22-2007, 07:32 PM
Do you have any #'s from your 402ci/l92 combo??
See5
07-22-2007, 07:36 PM
Me? 496/475
JoeyGC5
07-22-2007, 10:06 PM
Does the vent line connect to the catch can only? Or I guess I should ask, are you using any engine vacuum on the catch can tank?
98C5LS2
07-23-2007, 06:29 AM
Thanks.
See5
07-23-2007, 06:45 AM
A small restricted line to manifold, just enough to stop huffing at idle.
wannasupra
07-23-2007, 09:20 AM
ever thought of using an evacuation kit with the catch can?
