Coilpacks?
Old 07-10-2007, 04:10 PM
2000Z28ls1's Avatar
Default Coilpacks?
I tried a search but it isnt working. No one ever metions about having MSD coil packs wondering and I read somewhere about them not being worth it so I was wondering is it worth it to spend all that money for new coil packs
Old 07-10-2007, 04:20 PM
Moderator
jimmyblue's Avatar
These motors have plenty good ignition systems. I
wouldn't bother.
Old 07-10-2007, 05:41 PM
Albosky's Avatar
definitely save your money unless you are running a ton of boost or a WHOLE lot of spray.
The factory ignition system will handle up to ~500hp no problem.
Its a show off mod
Old 07-10-2007, 05:46 PM
getthesand0ut's Avatar
do ls7 coilpacks work on our motors? and what is the most you pay for them if they had 30 miles on them
Old 07-10-2007, 06:27 PM
staringback05's Avatar
just get the ls1 coilpacks....
Old 07-10-2007, 06:37 PM
2000Z28ls1's Avatar
alright thanks guys
Old 07-10-2007, 06:57 PM
cant seem to find any ls1 coil packs right now used..
Old 07-10-2007, 07:06 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
I emailed this guy about a month or so ago and he had some ls7 and ls2 stuff he might have ls1 stuff also. valvegod@aol.com
Old 07-10-2007, 07:53 PM
JGA
JGA's Avatar
They have a high failure rate. I had them on my car for 4 months. Many instances of P0300 codes. Finaly major misfire on multiple cylinders. Sent them back to MSD under RGA and 4 were replaced. 3 dead and 1 low output.
When I got the set back I was foolish enough to put them on again. After one drive my motor started to misfire again. Many people are experienceing failures. Stay away. I plan to put my stock coils back on and then chuck all 8 into the dumpster. $600 waist of money.
Old 07-10-2007, 09:12 PM
2000Z28ls1's Avatar
Well thanks for everyones input looks like im putting that 600 bucks toward something worthwhile. I'm gonna do apfull tune up here soon and is it worth the extra money for the Iridium NGK spark plugs or do the normally V series work really well for a lightly modded motor?
Old 07-10-2007, 09:30 PM
LS1NUT26's Avatar
V series would work just fine
Old 07-10-2007, 09:34 PM
2000Z28ls1's Avatar
Cool sweet save me like 30 bucks
