Grinding Gears
Old 07-10-2007, 04:16 PM
FastB's Avatar
Default Grinding Gears
So I was going to drive my car to work today when I left the neighborhood and my trans. grinded 3rd and 5th gears. I turned around and put it in the garage and got in my truck. My dad and I just put new trans fluid in it 3 days ago. Wasn't having problems before this. Any ideas? I was not driving hard when it did this. My ex brother in law runs an AAMCO so I called him and he said it could be a number of things. Any thoughts or trustworthy transmission shops around the North part of Houston?
Old 07-10-2007, 05:33 PM
ae13291's Avatar
do u want info on ur tranny problem or do want info about Houston?????????????
Old 07-10-2007, 06:28 PM
FastB's Avatar
Well, I guess if I could figure out what it could be then that would be a start. That way when I take it in to get fixed if I have to then I will have a little bit of a notion as to what is going on.
Old 07-10-2007, 06:32 PM
Krab's Avatar
I'm telling ya, try flushing out the old fluid via the bleeder valve on the slave cylinder (don't let the reservoir run dry), then bleed the system with a mityvac. It's cheap and it's probably the cause of several guy's problems when they experience this.
Quick Reply: Grinding Gears
