AH HA!!! i was wrong yet again!!!
ok so i had this very loud squeek coming from my engine (97 lt1 m6)..i took it to my mechanic..he told me it was the alternator.so i had that rebuilt..and the squeek got louder..i took the alternator off and spun it by hand..a squeeky noise was coming from it. i took it to autozone to check it out, i was told it was in perfect working condition.today on my way to work the squeek got even LOUDER!! and it gets louder when i turn the ac on!!!! (note: my ac is working just fine though..)
my question is, my ac compressor cant be bad since it still puts out ice cold air, right? what could this be??? and how much am i looking to spend having a mechanic doing it for me??thanks
Originally Posted by ROCNDAV
Remove the belt and check all of the accessories. My bet it's the tensioner.
Originally Posted by RBS_97Z28
Try putting a new Serpentine belt on it 1st before you start taking everything off. That may be what's causing the noise.
Not trying to hijack your thread, just don't want to start a new thread when we are having the same problem. I might try getting a different belt from the dealership and see if that helps before I take off the alternator and have it rebuilt.
Ive been told that even though my ac works just fine..that it may be the clutch in the ac..would it be best to replace just the clutch or get a whole new ac unit? about how much would i be looking at in labor costs for swaping ac compressors? thanks
alot of times it is best to have a new compressor put on than it is to have a clutch replaced . you also run the risk of having the compressor go out after putting on a new clutch and have to buy it all over again.
Originally Posted by Josh Nickelsen
I am having the same problem. I am positive that it is coming from the alternator. Mine started doing it after I put a new belt on. I got the belt from Autozone. Do you think a different belt would help?
damn, now i realize that the original post was made by an LT1. Sorry dude, i dont know if our conditions are applicable since im sure the serpantine accessory system is totally different. Im sure me and Josh Nikelson are having the same problem though. The service bulliten was for LS1's that fell within a certain vin number catagory. They ran from 98-00 and i see you qualify. Might want to eyeball it as well and see if maybe you may have the same problem. Somebodys gonna fix this!
You can get the compressors rebuilt or aftermarket much cheaper if you shop around. Think I paid around $280.00 for a rebuilt one. Better yet check up here for someone that pulled their AC. You can have a compressor that works but still makes noise due to bad bearings or problems with the clutch.
As said above, run the engine without the belt to see if you still get the squeal. Turn each pully by hand checking for noise of especially binding. If it's that loud I would think it was the belt slipping, it's cheap so replace it anyway if you haven't done it in a while.
