how often should I change my springs?
Originally Posted by dubrado
I have some 918s....thanks
It really depends on the cam... If its an agressive lobe, check the spring pressures at 15K and every 5K after that. If its a mellow lobe maybe check at 25K and every 5K afterwards. Too many variables will affect spring life, so just check one or two to be sure.
However you might want to verify that you did not get a set from the bad batch from last year that seem to be breaking all over the place.
Originally Posted by GuitsBoy
You should have changed them yesterday!!!
I've got an old batch from a couple years ago....it's been around 15k atleast
