accufab tb sensors
Old 07-10-2007, 10:42 PM
Justa Z's Avatar
Default accufab tb sensors
I have a ford 90mm accufab tb but there is no sensors, if i use a ford iac and tps sensors will my camaros stock pcm read them? Thanks
Old 07-12-2007, 07:26 PM
newby's Avatar
Default according to others, yes if you re-wire it
https://ls1tech.com/forums/pcm-diagnostics-tuning/666527-gm-ford-tps.html
somebody on here was making a plug converter that had the ford connector on one end and the gm on the other but that would be an easy diy
search for ford tps and you get a lot.
