boost takes out another lucky #7
Here are the motor pull pics...and some other random fun that came about with the pull!
This is how your supposed to use a cherry picker right?
Well it worked i guess!
Long block!
First signs of trouble!
OK well this was really the first sign on trouble!
Wheel GAP!!!!!!!
Some random fun after pulling the motor!
This is what you all wanted to see!!!
Some jbweld should fix that right up....right????
Long block!
Wheel GAP!!!!!!!
thanks mighty....she is a hottie
yea this is the 2nd time that motor went on me...first time i got cursed with an oil issue and spun a bearing...had to rebuild FAST (im military and was on leave at home when it went) so could not afford the time to get forged internals...so it just go built back stock. this time its getting BUILT tho so hopefully the new motor lasts for a while.
Originally Posted by Got Me SOM
more pics of the girl are required who cares bout your motor!
0000000000000000000000000000
hahahaha
You guys are way too damn happy for pulling apart a blown motor haha.
i remember the thread when you blew up the motor last time, you had it all apart all over that little garage lol. i dont remember any girl pics in that thread. keep the pics coming, of the girl
good luck with the motor rebuild
ouch that sucks to see all that engine destruction...but having good friends around does make it suck less though...its either that or the girl "makes it all better" for you.
Originally Posted by ninetres
LS1s always pull the hottest *****. The pic with the wire harness gave me wood, lol. She's a keeper!
the rest of the oil & coolant looked normal how did you manage the milkshake under the valve cover? much head damage from the broken ringland?
Looks like kinda tightish ring end gap? That was axctly the reason why i lost a #8 stock piston on spray was it had like a .005" ring end gap on the top ring and never detonated to the point where there was damage to plugs or never showed over 3 degrees of KR but lifted a corner and mulched the chunk and cracked the sleeve... it was ugly. Happend at the end of a spray pass and pushed the head gasket from cracking the block etc... Yeah nice chick, id throw it in!
i had damage to the plug....
i was runnin 5.5psi not sure on the exact timing/afr but it was safe...i think i got a tank of bad gas from a podunk gas station in texas and it detonated
and thanks guys for the comments about the girl!
