Sudden soft clutch pedal?
Well here is the quick story, I was doing a WOT pass up to ~150 or so until I noticed I had a pretty violent vibration. I think its coming from my driveshaft, as everything else has been tried and the shifter was vibrating significantly. Regardless, after doing this pas, my clutch pedal has been very soft. I have recently switched from a ram clutch to a LS7/fidanza alum flywheel about 4-5 thousand miles ago. Any ideas on what to check for this? Could a fluid flush remedy the situation, or do you think the vibration could have caused the problem? The car still shifts fine, and the clutch seems to hold the power fine still, So I am leaning toward the fluid. Just looking for some insight.. Thanks, Jeff
