General Maintenance & Repairs - blinking ses light?
BurtReynolds
07-11-2007, 02:16 PM
It starts blinking at around 2700- 3000rpm.I had installed ls6 intake and 3.73 a while back.
jmilz28
07-11-2007, 02:35 PM
Do not drive it. Flashing MIL indicates something is causing damage to catalytic converter and possibly engine. Get that fixed immediately.
Disturbed Bird
07-11-2007, 02:37 PM
im 100% sure that means you have a miss fire go by advanced auto parts and have them scan it its free. and it will tell you what cylinder it is. its no big deal probly just need new plugs or wires
John02Hawk
07-11-2007, 02:40 PM
:stupid:
NHRAMAN
:stupid:
X 2. :judge:
2001NBMZ28
07-11-2007, 02:43 PM
Usually it's a misfire - should be a code stored in the PCM.
BurtReynolds
07-11-2007, 02:47 PM
So what can I do to fix it.I thought it was a misfire?
2001NBMZ28
07-11-2007, 03:45 PM
Have the car scanned for any codes, that'll help nail it down.
kaos_
07-11-2007, 04:00 PM
mine blinked when the rain killed my O2 sensors. the car would surge like crazy. i got it home and replaced the O2s. problem solved!
GTO1_OHIO
07-11-2007, 04:32 PM
Blinking is an indication that a catastrophic failure could occur. Have it looked at immediately.
jmilz28
07-12-2007, 12:17 AM
Go get it looked at by a real mechanic, scanning for codes is only a step and AZ cannot help you. 4 things can cause misfires/running rough:
1. Air
2. Fuel
3. Spark
4. Mechanical
with lots of options at every step to rule out.
It's a process to diagnose, either dig in or pay someone to do it.
Sunset'01Z
07-12-2007, 01:18 AM
no offense dude but you shouldnt give people advice like that. misfires can be caused by improper fuel delivery too. the code scanners wont tell you whats wrong with the car, it gives hints at areas to check to find out whats wrong. plugs and wires also wear individually and/or gradually for the most part and will not cause a flashing MIL light.
to the OP: please do not drive the car unless you absolutely have to. you may cause damage to your cats and possibly your engine too. get the car to a professional technician so it can be diagnosed and repaired properly.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
