Pacesetter install DONE!
Old 07-11-2007, 09:56 PM
brntOrgZ28's Avatar
Default Pacesetter install DONE!
Finally got my headers and y pipe in. It went smooth other than the fact the y pipe vibrated my floor pan!.I also put a 160 stat,Lid,3.73's and Got it tuned!
The car really came to life other than it wont hook what so ever and it is a A4 car!
Old 07-11-2007, 10:36 PM
SSANIMAL's Avatar
Did You Have To Take Off The Steering Linkage? I Know I Did When I Did My Headers.
Old 07-11-2007, 10:57 PM
djsanchez2's Avatar
Did you do the BFH mod on the drivers side? (the rail under the drivers seat), oh yeah almost forgot, i did have to cut about a half inch odff the stock i-pipe to get the proper clearance. It was pushing the catback back out toward the bumper and causing the hangers too much stress.
Didn't have to remove anything other than the coil rails and the stock headers, when i installed mine. It does pull a bit harder up top too and it has a lot more down low.
Old 07-11-2007, 11:05 PM
blownta00's Avatar
good work
Old 07-12-2007, 03:31 PM
brntOrgZ28's Avatar
No, I took off the coil rails,stock exhaust,and cut the little ear off the side of the block and everything slide right into place.
Old 07-12-2007, 03:34 PM
brntOrgZ28's Avatar
Thumbs up
No I never had to use the BFH lol!..but i did use the BFPB (big F*cking pry bar)..to pry down on the y pipe but i think i am going to cut off a little bit of the y-pipe if i have any problems on down the road! Yea mines def run completely different but i cant tell what gave me what because i done alot at one time!
Old 07-12-2007, 03:36 PM
brntOrgZ28's Avatar
Originally Posted by blownta00
good work
Thanks!
Old 07-12-2007, 07:12 PM
kbronSS's Avatar
damm....whats up with all these questions....when i did mine, i didnt have to do jack **** to get them in, not even the spark plugs.
