why are the .006" and .200" specs of a cam not advertised?
I'm trying to make a comprehensive spreadsheet(for my own research) but i need the data from all of these cams at their .006" and .200 Lift as well as the advertised .050" lift.
i've been unsucessful in finding this information for the vast majority of cams(possibly because this information is proprietary?) and was wondering if any of you could help me locate this data?...
I'd be happy to post up my excel sheet when it's complete.
Thanks fellas,
Jeff
Thanks fellas,
Jeff
Thanks fellas,
Jeff
Thanks fellas,
Jeff
Originally Posted by GOaT Cheese
It is an outdated sales strategy. The camshaft makers typically like to list the "advertised" duration of a camshaft to make it look bigger. The thought there being to sale more cams. But the real performance guy needs to know the duration at several lift points to help determine the lobe intensity and shape. Cam companies feel that us morons only look for the biggest numbers in the catalog to make or bump stick decisions. Anyway, that is why it is so difficult to find the numbers that you really need to make a good cam choice.
Kinda seems backwards in the LS1 world how cams arent advertised using advertised duration.
You can get the info for Comp lobes off their website. Most cams use their lobes. For those that don't, just find the Comp lobe with similar lift and .050 duration. That should get you pretty close, as the laws of physics are the same for all the grinders.
I've attached a file with the ones I use in my sheet.
