ABS/TCS removal
ABS/TCS removal
Beside the black tape mod, does anyone know how to remove the ABS and TCS indicator lights when you do the !ABS and !TCS mod?
I heard that some fuses can be pulled but I'm not sure which ones.
Originally Posted by great421
There's a wire off the module (in the dash) you can ground to resolve this, SJM (a sponsor) knows the one.
That would be great. THX
I believe it is BCM-controlled however. The BCM gets a signal from the TCS box and then decides what to do with the TCS light in the dash based on that input.
I've heard you can get a BCM out of a non-ABS/non-TCS car, and it will eliminate the lights as well, but I have no idea the other specifics about swapping a BCM.
