questions about lq4 build
found a lq4 dirt cheap with 70k from a junkyard out of a '04 truck, local builder said i would have to replace pistons and crankshaft, is this true?? ive done alot of searches but cant see if anyone left bottom end alone. need to put into ls1 camaro. builder hasn't seen engine yet, just says it has to be done
It seems hard to get responses about 6.0 builds around here. I am doing one now too. Anyway, I dont know why you would have to replace the crank. You may want to replace the pistons to up the compression.
Dumb Ass Vette Moderator
Most likely the pistons and crank are OK, but have them checked. It would be a good idea to place the rings and have the block honed to clean up the cylinder walls. If you decide to replace the pistons to increase the compression level, I would overbore the block 0.030". Also do new cam, rod, main bearings.
Keith
Keith
Originally Posted by sstoz06
found a lq4 dirt cheap with 70k, local builder said i would have to replace pistons and crankshaft, is this true?? ive done alot of searches but cant see if anyone left bottom end alone. need to put into ls1 camaro
