T-REX cam
T-REX cam
has naybody had any experience with it? it sounds like a pretty vicious cam and i was thinkin about gettin one. think you could put it in a stock-headed ls1 without pv clearancing?
first off...have you tried searching??
its only been around for a few years...quite a few have tried it. but honestly there are better more up to date cams out there of similar potential.
and the cam was designed to work on stock heads...so ptv is close...but acceptable assuming stock heads, valves and gaskets
Check out internal engine section.. there's no one best cam, you need to figure out what you want from the car. Also what kind of street manners are you looking for, or will this be a drag car? Post in there and you can get a lot more answers. Bigger is certainly not always better. Depending on what you want, go something in the high 220's -230s. Check with some sponsors and they can do a custom grind specifically for your needs. Your also going to see a huge gain by putting on a set of heads and letting that thing breath. Boltons before your cam will make your cam run so much better. A good flowing exhaust is also extremely beneficial
